1990 Ford Taurus Split CV Boot
Good luck and let us know. :)
peppemrj
[quote:0e74584a84="peppermrj"]Does the cv joint click in tight turns? If so it does need replaced. If not you could try a split boot repair kit which is much easier to do with minimal tools. You cut away the old boot, clean the joint, regrease the joint, and install the boot.
peppemrj[/quote:0e74584a84]
1. Important to clean joint VERY good
2. Important to put lots of new grease back into it
3. Important to install boot so parting surface and screw holes are absolutely clean. If you get grease on the surface and in the holes an tighten the screws, you risk spinning the parting surface and tearing the holes in the rubber out.
4. Best to glue parting surface for better seal.
Suggested Repair
If the CV joint does not click during tight turns, use a split boot repair kit from an auto parts store. Cut off the old boot, thoroughly clean the joint, pack it with plenty of new grease, and install the split boot. Keep the parting surfaces and screw holes completely clean, and glue the parting surface for a better seal. If the joint clicks, replace the joint rather than only the boot.
Conversation Summary
The owner of a 1990 Ford Taurus with a split CV boot asked which tools were needed and whether the joint should also be replaced. The expert said a clicking joint should be replaced, but otherwise a split boot kit is easier and requires minimal tools: remove the old boot, clean and regrease the joint, and install the new boot. The kit should be available at parts stores with instructions. Another contributor stressed thorough cleaning, ample grease, clean mating surfaces and screw holes, and gluing the parting surface.
