Idling problem
QWERT97
Ford-Taurus-143,000- 1996 make
Recently I noticed that while idling the rpm goes down under 1000 (hovers around 800) or so and sometimes the car starts shaking. Does the car need tuning or is it something else? I do not want to spend $100 to take to a dealer for diagnostics.
Mar 15, 2006 at 3:57 AM
RAYHUT
  • 134 POSTS
adjust your ideling screw and that should do it
Mar 15, 2006 at 10:05 PM
QWERT97
[quote:26d477b373="rayhut"]adjust your ideling screw and that should do it[/quote:26d477b373]
Thanks for the reply. I also wanted to mention that if I put the gear on neutral then the shaking stops. Does that in any way change your opinion that it is the ideling screw?
Thanks in advance.
Mar 16, 2006 at 12:05 AM
