2003 Ford Taurus P1400 EGR Sensor
Suggested Repair
Confirm the DPFE/EGR sensor hoses stay connected. With the engine running, attach a vacuum gauge to manifold vacuum and watch it for 2-3 minutes. A dropping reading suggests an exhaust restriction, such as converter debris in a pipe or muffler. Excess backpressure can blow the sensor tubes off. P1400 indicates the EGR position sensor circuit.
Conversation Summary
The owner of a 2003 Ford Taurus had a flashing check engine light, found water in a spark plug tube, and replaced the plugs and wires. A melted DPFE sensor was also replaced, but its hoses kept blowing off. The EGR valve and solenoid tested OK, and the rear catalytic converter was replaced after the car was driven while misfiring. The light stayed off for two days, then P1400 returned. The expert identified P1400 as the EGR position sensor code, noted that a flashing light can damage the converter, and recommended a manifold vacuum test to check for exhaust restriction that could blow the sensor hoses off.
