1999 Ford Taurus Clicking No Start
CAP HOG
I have a 99 Ford Taurus. This morning when my wife tried to start it all it did was make a clicking noise. It has power because the lights come on. I suspected the starter at first but, when you try and turn it over it makes the click and then the windshield wiper will run once even though the switch is not turned on for the wiper. Is this a short? or maybe a bad wire? Any help would be much appreciated.
Thanks.
Dec 31, 2006 at 5:50 AM
TAURUSWHEEL
  • 718 POSTS
Most likely the battery is low, a while ago the battery on our 99 Taurus shorted a cell, same thing I turned the key to start, a bunch of clicking which usually, not always though, indicates low volts, and the wipers started running.. had to replace the batt on our car..
Dec 31, 2006 at 8:35 AM
Suggested Repair
Test the battery for low voltage or a shorted cell and replace it if it fails. A weak battery can cause the clicking and unexpected wiper movement before the starter is replaced.
Conversation Summary
A 1999 Ford Taurus would not start and only clicked, although the lights still worked. Turning the key also made the windshield wipers run once with the switch off. The expert said this most likely indicates a low or failed battery, based on a similar 1999 Taurus whose battery had a shorted cell and needed replacement.
