98 Taurus noise
BRANDON RICHARDS
  • 1998 FORD TAURUS
I hope you could help me on a question. I have a 98 taurus with 178,000km it has a 3.0 24 valve. The problem is that when the car starts it makes a grinding noise coming from the a/c clutch, when it engages it doesn`t make a noise what is causeing it to make the noise and what dod I need to do to fix it? P.S the airconditoning blows ice cold air
Thanks
Tuesday, March 21st, 2006 AT 7:05 PM
KOZUBH
  • 7 POSTS
It sounds just like your problem is similiar to the the noise that my 98 grand Marquis makes. I believe that your problem is the A/C clutch that is attached to the air conditioner compressor. Normally, when the a/c is not needed, the pulley just free spins the the pulley on the a/c compressor clutch. Howver, when A/c is selected the clutch engages the a/c compressor and it compressors the refrigerant. With all the miles that you have, I would just have the a/c compressor and clutch replaced as a unit. Good luck.
Tuesday, March 21st, 2006 AT 7:14 PM
