2004 Taurus slight RPM fluctuation while at idle?
JAKIN
  • 2004 FORD TAURUS
My wife and I were test driving 2004 and 2005 taurus's this past weekend. All the ones we test drove were either the SES or SEL with the 24 valve 200hp V6 engine. We noticed that sometimes, at a stoplight, when you first start it, or right before you shut it off, basically at idle, the needle for the rpm's would fluctuate. The needle wouldn't move much, it would just kind of hover/slight bounce around 1,000 rpm's. It didn't happen on every taurus, but it did happen on more than one and it was not consistant on any of the ones we drove. At first I thought it might have been the timing that was off, but then I realized that these fancy new cars have computers or sensors that control the idle and you really can't adjust it anymore. I am not sure what this could be or is this just a newer taurus thing? Any help would be greatly appreciated. Thanks in advance!
Tuesday, July 11th, 2006 AT 6:55 PM
TAURUSWHEEL
  • 718 POSTS
If you're looking to buy, definitely get the 24v, better and way more stink then the 12v, gas mileage is not bad, the extra oomph is worth it, I have a 99, the idle is right around 850 or so. When first started hot cold whatever, it's up around 11-12, then comes down. You're right, all functions are non-adjustable by the end-user, that's you.
Tuesday, July 11th, 2006 AT 9:35 PM
