check engine light?
78,000 MILES • 6 CYL • FWD • AUTOMATIC
ALAN514
  • 7 POSTS
December 16, 2008
Dear Sir or Ms.:
My wife's 2003 Ford Taurus had the Check Engine Light come on yesterday. I took the car to "Autozone" Auto Parts today and they plugged in their Scanner and checked the Diagnostic Codes for FREE.
It came up with two codes: P0306 and P0316. Autozone printed me out a couple of receipts which had more details on them.
For P0306 it said that there was a misfire that occurred in cylinder # 6. The powertrain control module monitors the crankshaft speed and has detected a misfire condition. Probable causes are: Faulty Spark Plugs, Ignition Wires, or Coil. Vacuum Leak, Injector Fault, or High or Low Fuel Pressure.
For P0316 it said Crankshaft Condition. Probable Cause: Crank Sensor Defective; Check Connector and Wiring to Sensor; Check Trigger Wheel for Damage.
Next I stopped in at a local Auto Repair place and talked with the Head Mechanic. He told me that you can't go by the slips that Autozone provided because they just want to sell parts.
The Mechanic said that I should bring the car in for him to connect to his scanner at $69.99 to pin-point the actual problem.
He said if I actually needed a Tune-up it would cost approximately $180. on top of the $69.99 Scanner price. Other parts for the Crankshaft Sensor would be extra.
I went home and followed the advice from the guy at Autozone; who told me to disconnect my Negative Battery Cable to Eliminate the Service Engine Soon light. That actually worked. I tried turning the car on and off twice and the light did not reappear. Although I did not take the car out for a drive.
Questions:
1) By disconnecting the Negative Battery Cable, did that also remove the P0306 and P0316 Error Codes from the computer in my car??? I do live in Ohio where at this time of year it is either Raining or Snowing. Could the Moisture in the air have caused a glitch to cause the Light to come on and the codes to appear???
2) If the Service Engine Soon light does come back on; what steps should I take? Should I get the Scan from the Mechanic, or should I just get the Tune-up and take a chance that it will fix the problem? Money is very tight and scarce right now, as I am unemployed and just receiving Unemployment checks which doesn't even pay all the bills.
3) The Mechanic said that I shouldn't drive the car if the Check Engine Soon light is on because it can damage the Catylitic Convertor. Is this True??? Although I think I need exhaust work anyhow because I am getting exhaust fumes coming into the car. Another expense later in time, hopefully when I get another job.
OK, your responses and advice would be appreciated. Sorry, since I am unemployed I can not afford to donate any money for a response.
Thank-you.
Alan514
Dec 16, 2008 at 4:51 AM
DAVE H
  • 13,383 POSTS
firstly ...if your mechanic plugs the car into his computer he will only get the same codes as autozone did ... so he will only replace the parts autozone have told you about .. the crank sensor ... the misfire code would come from the crank sensor fault .. so they are basically the same fault one repair would fix both .. it could be the wiring on the crank sensor got damp due to weather conditions and this caused the CEL to come on ... if the light has not come back on after you drive it around for a while I would blame it on the wiring and look into that first if it does come back on ?? Lets use this guide to scan the car correctly
Dec 16, 2008 at 5:06 AM
ALAN514
  • 7 POSTS
December 16, 2008
To: Dave H.
Thanks Dave, for your quick response. Sounds like you are sure that if there is a problem it probably is the Crank Sensor or the wiring leading to the Crank Sensor. Just where the heck is this Crank Sensor located at anyhow???
This is the first that I even heard there was such a thing. I tell you, these newer cars are garbage. I wish they would build car back like they did in the 1960's. I am 54 years old and I used to work on cars when I was younger, but pretty much gave that up when they started making cars so complicated.
As I said in my original posting - I am unemployed and my unemployment checks don't even pay all of my bills. As a result I am behind on everything. I am at the point where I am going to have my other car, a 2007 Pontiac Grand-Prix GT Reposessed by the bank and I will have to depend on this 2003 Ford Taurus that I am having trouble with for going on job interviews and also for getting to work when I do get a new job. Plus in the County where I live in Ohio I am required to have this car's emmissions checked coming up in January 2009. So I need this car running with no Engine Check Lights or Codes in a hurry.
Again, Thanks for your Response.
Best Regards;
Alan514
Dec 16, 2008 at 5:40 AM
ALAN514
  • 7 POSTS
December 16, 2008
To: Dave H.
One other thing...
When the Mechanic told me he was going to connect the car to a Scanner, I thoght he meant a different kind of scanner or Diagnostic Electronic Computer where you connect leads to places on the motor to get readings, and not just plugging in a metter to the connector under the dashboard.
Alan514
Dec 16, 2008 at 5:44 AM
DAVE H
  • 13,383 POSTS
all new cars are controlled by a PCM (computer) every vehicle nowadays tells you where the fault lies by plugging in under the dash ... he won't do any more the autozone did ?? I would be checking the wires to it first before replacing .. but as you can see it's an easy replacement part .. DIY job .. this picture is from a 3.0L 2V let me know which engine you have for another picture .. let me know Crankshaft Position (CKP) Sensor (3.0L 2V)On lower right front of engine. See Fig. 1 . Crankshaft Position (CKP) Sensor (3.0L 2V FFV)On lower right front of engine. Crankshaft Position (CKP) Sensor (3.0L 4V)On lower right front of engine. See Fig. 5 .
https://images.2carpros.com/forum/automotive_pictures/266999_ckp_3.jpg
Dec 16, 2008 at 6:57 AM
ALAN514
  • 7 POSTS
December 16, 2008
To: Dave H.
Wow, Pictures!
I actually do not know which of those model Ford Taurus' that I have. I know there are no FFV signs on the Fender or Trunk Lid advertising alternate Fuel.
I am sure that it has a 3.0 Liter engine sitting sideways in the engine bay. I am guessing the 2V and 4V designates how many Valves per cyclinder? It is not a "SHO" Model; so I would have to guess it is the 3.0 2V model.
It does have bucket seats and the Automatic Transmission Shifter in the Center Console.
I tried looking on stickers at the front of the engine bay and inside the driver's door, but I didn't see anything that told me anything relative.
I did open the engine bay and standing by the front passenger side fender I saw some electic wiring and a plastic connector hanging down just to the left of the Serpentine Belt that runs to the alternator and other places.
I couldn't hardly get my hand down in there to even touch it, let alone check connections or change anything. It looks like you would have to practically lift the motor out or drill a hole through the inner fender well to get to it. With it hanging so low to the bottom of the engine I can see why it would get a lot of water on it splashed up from the road.
So, I saw this stuff hanging there to the left of the Serpentine Belt, but not knowing what a Crank Sensor looks like, I am not positive about it. Is the Crank Sensor just something that plugs into a wiring harness, or do you have to un-bolt something from the engine?
Thanks for all your help.
Best Regards;
Alan514
Dec 16, 2008 at 8:06 AM
DAVE H
  • 13,383 POSTS
the actual sensor is where my arrow is pointing .. it just bolts on with one bolt .. unplug the connector that the other arrow points at ..as you can see the connector goes onto CKP
https://images.2carpros.com/forum/automotive_pictures/266999_ckp2_1.jpg
Dec 16, 2008 at 9:04 AM
DAVE H
  • 13,383 POSTS
This is a picture of the 3.0L 4V .. it also gives you a better idea of where the CKP is actually located ... it sit's almost connecting to the crank pulley ??
https://images.2carpros.com/forum/automotive_pictures/266999_30L_1.jpg
Dec 16, 2008 at 9:16 AM
ALAN514
  • 7 POSTS
December 16, 2008
To: Dave H.
Thanks Dave. It's dark out there now, but tomorrow I'll have to take a better look at it. Perhaps if I pull the car up on a set of ramps and then crawl underneath, I can then get a good look at it and an idea if I want to try tackling the job myself or not.
You don't happen to know what a Crank Sensor might cost me do you? $20.? $50.? $100.?
I did call that Mechanic up that I talked to earlier to ask him how much it would cost to replace the Crank Sensor. He told me $100. with Labor. Not too bad, but if I can do it a lot cheaper myself, I'm all for that.
Thanks again for your help.
Best Regards from Akron, Ohio
Alan514
Dec 16, 2008 at 9:19 AM
DAVE H
  • 13,383 POSTS
trust me when you see it .. you will do it yourself .. it's one bolt and unclip the wire's ... because of where it is, it may just need a good cleaning and check of the wires .. ??
OEM dealer(ford) part price is $45.00 ... you can probably get it a lot cheaper at autozone ..
Book time for labor is 1 hour ??
Hope this helps ... if I helped feedback is alway's appreciated
Dec 16, 2008 at 9:31 AM
ALAN514
  • 7 POSTS
December 16, 2008
To: Dave H.
It will all probably depend on the weather, because I will have to try to do this outside. The weatherman said we have a big storm coming our way.
Thanks Big Time Dave for all the excellent help.
I did try to give you some feedback points, but they said I only had 0.2 points to give. When I typed that in, they said why are you trying to enter Zero. When I removed the Zero and just entered .2, they still asked, why are you trying to enter Zero. But I may try it again though.
Best Regards;
Alan514
Dec 16, 2008 at 10:07 AM
DAVE H
  • 13,383 POSTS
no problem .. good luck with the repair and the weather .. ... let me know on the outcome of the repair either way
Happy xmas and a good new year 2009
Dec 16, 2008 at 10:12 AM
ALAN514
  • 7 POSTS
December 24, 2008
To: Dave H. and anyone else interested in my story:
After originally having Codes show up saying that I had something wrong causing a Misfire on Cylinder # 6 and also something wrong with my Crankshaft Sensor (Not to be confused with the Camshaft Sensor) - I disconnected the negative side of the battery to get rid of the "Check Engine Light" and the Codes.
I ran the car on a trip to Wal-Marts and back home (about a 30 minute trip altogether). This is my wife's car and I noticed she never jumps on the gas at all to give the car any real accelleration and to burn the GUNK out a little. So a few days later I drove the car myself. instead of sitting in the passenger seat.
I floored the accelerator a few times and drove the car up at 60 to 65 a little. I accellerated quickly from stop signs and red lights. I did not baby the car.
All seemed to be running good, with no "Check Engine LIght" showing back up at all. We are in a county in Ohio which requires Emmission testing of Vehicles every two years, and this car was due to be Checked by February 2009.
So while the car was running good I took it in for the Emmissions test. They looked under the car with a mirror, connected their computer under the dashboard to get their readings, and they pressure tested the gas cap.
The results were that the car passed the Emmissions Test in every category. I then went to the License Bureau and purchased my new License Plate Stickers for $49.99.
So I guess the light coming on and the resulting codes was just an accident. I guess I lucked out!
End of Story.
Best Regards and Merry Christmas to All !
Alan514
Dec 24, 2008 at 3:06 AM
GJONES9876
Computer problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic
What do I need to check when I was told the check engine code says low fuel pressure?
Oct 24, 2020 at 4:38 AM (Merged)
BLACKOP555
  • 10,386 POSTS
can you tell me the code that showed up in p**** foramt?
GJONES9876
The codes are P1131, P1132, and P1151
BLACKOP555
  • 10,386 POSTS
p1131- lack of upstream heated oxygen sensor switch [ sensor indicates lean bank 1]
p1151-lack of upstream heated oxygen sensor switch [ sensor indicates lean bank 2]
most likely since both are showing lean i would go and clean the maf sensor with QD contact cleaner. dont touch the wires or youll damage them. just spray them with the cleaner. if thats not it check for a exhaust leak before the sensors.
GJONES9876
Thanks for your reply, would you tell me where the Maf sensor is located.
BLACKOP555
  • 10,386 POSTS
the MAF sensor is the mass air flow sensor. it is located right after the air cleaner box on the air hose going to the throttle body.
RAM5ER
I own a 2003 Ford Taurus V6 DOHC and my check engine light came on. I went up to the local Autozone in order to check the code which was P0141. This code is for the Heated Oxygen Sensor bank 1 sensor 2. I replace the sensor but check engine light is still on. I unplugged the battery and the light went off for about 10 min but it came back on. Went back to Autozone and still had the same code. Does the computer need to be reset by the OBDII scanner or does unplugging the battery reset the computer. Any other suggestions?
Oct 24, 2020 at 4:39 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
May be a problem in the harness as one other possible cause. IF the sensor was a universal one as oppossed to the one meant for the system, that may have a bearing on it. There is a chart to troubleshoot this code that is best to follow before replacemnt of a suspected sensor. A code is a starting point to diagnosis and jumping from the code to a guess based on the description is gamble at solving the problem.
RAM5ER
Thank you for your quick response. fyi... I did not use a universal sensor, the one a purchase was for my Taurus. Where do I find the troubleshooting chart?
SERVICE WRITER
  • 9,123 POSTS
If you look on the link on my signature, it will take you to mitchell manuals.
IT will be listed under tests with codes.
JJBBAARR01
I dont have anything to donate today, but maybe soon.
I need to know about the check engine light coming on. I had it check out at Advance Auto and the saleman said I needed to change the spark plugs and wires. I did that and the light did not go off. What else could it be? I have replaced the transmisson a year ago brand new. I have a bad master cylinder to replace also, and a power steering pump.
OBXAUTOMEDIC
  • 3,715 POSTS
[quote:656608ece8="jjbbaarr01"]Engine Performance problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic 155000 miles
I need to know about the check engine light coming on. I had it check out at Advance Auto and the saleman said I needed to change the spark plugs and wires. I did that and the light did not go off. What else could it be? I have replaced the transmisson a year ago brand new. I have a bad master cylinder to replace also, and a power steering pump.[/quote:656608ece8]
What was the engine code? If it was a code for a misfire then there could be other reasons for the misfire. It could also be that the code just needs to be cleared. You can go back by Advanced and have then recheck the codes, WRITE THEM DOWN, if still tell you about the plugs and wires then ask them to clear the code. If engine light comes back on within a day or so, depending on the driving distance. Then go back and have them pull codes again and post them here.
EMRALDBTTRFLY
car is sluggish at take off and when it shifts gears
  • 75,988 POSTS
https://www.2carpros.com/articles/service-engine-soon-or-check-engine-light-on-or-flashing
Check engine light on
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
PINKKIKKI
if you try to accelerate hard once the car reaches about 50mph it starts to jerk and will not let you accelerate futher until you let off the gas and ease back into it. Also, if you start up a hill and ease into the gas it jerks once again at about 50mph. I've changed the plugs,plug wires,fuel filter,transmission fluid and filter. The battery light comes on pretty regular so i thought the problem could be electrical but no check engine light.
2CARPRO JACK
  • 11,533 POSTS
If the battery light comes on,you need to address that problem first. have the charging system load tested, battery and alt.If the system voltage gets too low, the car wont perform properly
JDOBBINS
2003 Ford Taurus Engine Light on for no apparent reason - what do we look at first?
One month ago had the AC Pulley assembly replaced and also the serpentine belt and the bearings/pulley involved with that.
BLACKOP555
  • 10,386 POSTS
get the vehicle scanned for codes and see what is stored. there are thousands of things that can be wrong cant just give you an answer on what to check first. if i was to guess check the gas cap
KELSEYFAMILY06
My engine light came on about 4 weeks ago, stayed on for about a week and went off. Then the other day it came back on. The car runs and drives fine. No hesitation or rough idle. Routine maintenance is done regularly. What could be the cause of this?
DLOBI
  • 125 POSTS
You need to have your local auto parts store or repair shop plug in a hand held code reader to see what caused the light to come on. Most places will get a code reading and be able to tell what tripped the check engine light for no charge. Then you can decide if it is a repair that you can do yourself or if you need a shop to fix it.
JANDT1111
I own a 2003 Ford Taurus and the a/c started "cutting out". It would get warm and then we'd shut it off for about 20-30 minutes and it work again for about 20 minutes. My father-in-law recharged it and it worked better than it has since I've owned it. Two days later it quit working altogether and then the service engine light came on. What could the problem be and can we fix it without taking it to a mechanic?
Oct 24, 2020 at 4:40 AM (Merged)
  • 31,937 POSTS
You must do two things here, first you will have to get a scan done to check for the set fault codes as indicated by the light on, secondly, i feel the the A/C system has a leak, you will have to get the system part charged and add a leak detector dye to try and help find any possible system leaks, start here.
ALNICOLE
My check engine light came on followed by the brake light while driving.
I'm going to replace the front disk brakes in the next few days, but is it possible for the brake problem to cause the check engine light?
  • 75,988 POSTS
BERITH
have a transmission leak
the other day the check engine light came on and the car has started to idle hard. reminds me of a car needing a tune up.
Any ideas? Thanks for your help. I am a mom--ann
Oct 24, 2020 at 4:41 AM (Merged)
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away!
BOSSSMAN4
My service engine symbol light showed up recently. MY transmission is fine so I wanted to know what may possibly be wrong with my car. Thanks
BMRFIXIT
  • 19,053 POSTS
Need to have it scanned for codes
most local shops and part stores should be able to help you
getting the codes
you can also check under the hood for any vacuum leaks checking PCV valve and its lines
check also gas gap
you can let me know what you have for codes
good luck
