Interior problem
2003 Ford Taurus 6 cyl Two Wheel Drive 118000 miles
there's a water leak under the roof but it's not comming from the sun roof but more like from the roof top side seams. What to do? Thank you.
Friday, September 19th, 2008 AT 9:17 AM
BMRFIXIT
MECHANIC
Clean sunroof drain
use compressed air
locate the drain at corners use the air to blow it out
SPONSORED LINKS
Friday, September 19th, 2008 AT 8:59 PM
KHOOPER
MEMBER
Easy fix go and buy a small tube of neoprene [the stuff that they put the windshields in with. Now where the foof and the windshield molding meet on the top of the van. Put a bead all the way across and come down on each side about one inch but you have to leave a grove for the water to go by on each side as there is a drain valley on each side. This will stop the water from going in underneath the windshield molding and on the inide of the windshield.
