2002 Ford Taurus parts and description
FOREST11
Engine Mechanical problem
2002 Ford Taurus 6 cyl Front Wheel Drive 140 miles
need information relater to alternator
May 3, 2009 at 1:23 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ee5b19e584="forest11"]Engine Mechanical problem
need information relater to alternator[/quote:ee5b19e584]
Ok, what info do you need?
May 3, 2009 at 1:25 AM
FOREST11
remove the old one and install new.
May 3, 2009 at 1:30 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry for delay...
Here are the steps...
Disconnect the negative battery cable with a socket wrench. Release the tension on the accessory drive belt so that you can remove the drive belt from the pulley.
Take off the mounting bolt on the right side of the alternator with a socket wrench and remove the bracket for the power steering hose. Remove the mounting bolts on top of the alternator, the front passenger wheel and tire assembly and the front fender splash shield. Remove the alternator splash shield with a socket wrench and take off the inspection cover for the torque converter.
Mount a tool to hold the flywheel so you can remove the crankshaft pulley bolt and crankshaft pulley. Lower the alternator so you can unplug its electrical connections. Disconnect the crankshaft position sensor and Oxygen sensor connector. Remove the lower alternator mounting bolt and B+ connector nut to remove the alternator.
Install the new alternator assembly by reversing the above procedure. Use a torque wrench to tighten the B+ connector nut to 71 in. lbs. and the lower alternator bolt to 18 foot pounds. Torque the crankshaft pulley bolt to 74. foot pounds, the upper alternator bolts to 18 foot pounds and the nut for the power steering hose bracket to 13 foot pounds.
I don't have access to any diagram today cause I am at my county job.
May 7, 2009 at 5:30 AM
