Coolant leaks at the left rear of the engine towards the firewall?
FNEMO1
  • 2002 FORD TAURUS
I have a coolant leak, when the car is cold, at first start coolant leaks at the left rear of the engine towards the firewall, it drips on the exhaust then the ground, after a few minutes of running the leak stops, I jacked it up but could not see where the leak is, I need the put the car on a lift to get a better view, I noticed a lot of moisture coming from the intake gasket. Fred
Monday, October 25th, 2010 AT 10:12 PM
SQM
  • 6,383 POSTS
You could have a gasket leak. As it leaks when the engine is cold but as it warms up all the components expands and possibly seals the leak.
You should do a pressure test when the engine is cold. This will create pressure similar to when the engine is running, it will make it easier for you to detect the leak.
You should be able to use the tester from your local auto parts store.
Here is a helpful video of how to do the pressure check:
https://youtu.be/W8kra65m15c
https://www.2carpros.com/articles/radiator-pressure-test
Tuesday, August 10th, 2021 AT 8:48 PM
