ABS light is on. How do we clear the code?
2002 FORD TAURUS
155,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBCHAR518
We removed the spindles and disconnected the ABS sensors while replacing the front ball joints / tie rods (turned the ignition on to move the steering wheel for better access) and the ABS light is on. How do we clear the code? The local Advanced / Auto Zone / Pep Boys are unable to clear the code and I’ll try disconnecting the battery for a bit tonight. Short of a $115 charge from the dealer for the privilege of clearing it, any other suggestions? Disconnecting the bulb doesn’t count :o)
Oct 25, 2010 at 5:38 AM
BMRFIXIT
  • 19,053 POSTS
If no ABS light before the work on the ball joints ,suspect that you had damaged the sensor at that side. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Apr 21, 2021 at 3:52 AM
BOBCHAR518
Thank You! it was the right front ABS sensor that was bad.
