2001 Ford Taurus Starter Clicks
KPRNCE4
I have a 2001 Ford Taurus SES with 113000 miles my oil filter leaked on my starter and possibly shorted it out. I have since changed the starter, tested the alternator and battery. My car still won't start. What else could it be? All lights on my dashboard light up and I have power but when I turn my key my starter just clicks as if it is not getting enough power.
Nov 19, 2006 at 12:16 PM
CATCH_15
  • 250 POSTS
Make sure the battery is fully charged. If the dome light dims a lot when you try to start it, the battery is probably low. If not, check to make sure the ground terminal is tight. If the battery isn't grounded well, you will have a lot of trouble getting the car started.
Nov 19, 2006 at 3:43 PM
Suggested Repair
Fully charge the battery and confirm the ground terminal is tight. If the dome light dims heavily while cranking, the battery is likely low.
Conversation Summary
The owner of a 2001 Ford Taurus says an oil-filter leak may have shorted the starter. After replacing the starter and testing the alternator and battery, the car still will not start; the dash lights work, but the starter only clicks. The expert advises confirming a full battery charge and a tight battery ground.
