2001 Ford Taurus
WJWKI04
  • 2001 FORD TAURUS
Electrical problem
2001 Ford Taurus 6 cyl Two Wheel Drive Automatic
How to Change a Dash Light Bulb in a Ford 2001 Taurus
Thursday, May 13th, 2010 AT 10:29 AM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable.
Tilt steering column to lowest position.
Remove instrument cluster finish panel.
Remove instrument cluster retaining screws.
Pull top part of instrument cluster toward steering wheel.
Disconnect instrument cluster harness connectors. Remove instrument cluster.
Remove and replace bulb
To install, reverse removal procedure.
Thursday, May 13th, 2010 AT 6:26 PM
