2001 Ford Taurus Dash Lights
NAVYVETERAN64
Electrical problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic
Sometimes all the dash lights go out except for the two turn signal arrows. The lights for the radio, temp controls, head lights, etc. all work.
It sounds crazy to say, but it seems to be cold related. The colder it is the more often I have the problem and sometimes after the car warms up, the lights come back on.
Can you please offer any advise?
Thank you,
Bill
Jan 21, 2009 at 4:27 AM
  • 110,248 POSTS
Bill,
Make sure the ground going to the dash is clean and tight. If everything appears ok, chances are it has to do with the body control module (BCM) which will require test equipment to test.
Aug 6, 2019 at 10:12 AM
