2001 Ford Taurus Fuel Pump?
ANGEL200161832
  • 2001 FORD TAURUS
  • 6 CYL
  • 200,000 MILES
I have a 2001 Ford Taurus for 3 years now. I didn't have a problem with it until like a month ago. First the computer kicked up bad cam sensor replaced that and everything was fine. Drove it for a little while and now the fuel pump doesn't kick on when we first start it up. We have to listen to see if it kicks on before we can even start it up. I know it's not the fuel pump because after it starts it runs fine and no more problems until you turn it off. What can this be?
Sunday, February 8th, 2009 AT 10:12 AM
BMRFIXIT
  • 19,053 POSTS
I would check fuel pump relay and ignition switch
then suspect fuel pump
Sunday, February 8th, 2009 AT 5:02 PM
ANGEL200161832
Thanks. That was what I was thinking of doing next. I will let you know if this works.
Thank You!
Sunday, February 8th, 2009 AT 10:51 PM
