2000 Ford Taurus Chirp at idle
82,000 MILES • 6 CYL • FWD • AUTOMATIC
There is a chirp noise at idle coming from the front end. I had the serpentine belt checked at it is fine. The mechanic thought it may be coming from the transmission. What could be causing a chirping noise if not the belt?
Jan 26, 2008 at 3:01 AM
FLEXY5
  • 512 POSTS
If you check right over the spot where the engine and trans bolt up together, just under the wire harness, you will see a sensor with a three wire connector on it. This is the camshaft position sensor. The shaft that drives it is called a syncronizer. They both need to be replaced, as this is probably the source of your noise. Verify the source of the noise and have a professional tehnician perform the repair since it has to be timed using a special tool. If you have any other questions, feel free to ask.
Dave
Jan 26, 2008 at 1:05 PM
