1999 Ford Taurus wont shift
FRED230
Transmission problem
1999 Ford Taurus 6 cyl Two Wheel Drive Automatic
the speed sensor went out will that cause the tnans not to shift
Aug 7, 2010 at 10:39 AM
BEARS0559
  • 7 POSTS
If it the sensor went out why does it still shift when I manipualte it. Also about how much would it cost to fix this type of issue. Also where is the sensor located?
Any advise is taken gratefully. Once I align the ignition switch I can shift into gear with of course my foot on the brake as normaly.
Aug 7, 2010 at 10:59 AM
BEARS0559
  • 7 POSTS
Your telling me it is a transmission porblem but I am not having any problems with the transmission it is with the shifter. I know how to manipulate it to go into drive and all other options and the transmission is not slipping. Do you have a better answer? Could there be a possiblity that it is something loose in the steering column? Please email me a bears0559@verizon.net I have not gotten an email from you like my brother does?
Aug 7, 2010 at 2:12 PM
BEARS0559
  • 7 POSTS
Where is that located could you tell me I just want to be knowlegdable. Although I am a woman I need to know these things. I know I can't fix it but would still like to know. How much would estimately cost me to fix this problem? Thanks for you answer I really appreciate. Liz
Aug 7, 2010 at 5:55 PM
