How do I reset ABS system?
150,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
MARK0415
  • 7 POSTS
ABS is engaged all the time with no ABS light on. Rear brakes were recently done with spring kit and new adjusters. How do I reset ABS system?
Jul 13, 2017 at 7:31 AM
STEVE W.
  • 15,409 POSTS
Sounds like you have a bad speed sensor that is telling the ABS unit that one of the tires is locked up. You will need a scan tool to read the actual speeds from the sensors and see which sensor(s) are not reading correctly. It only takes a minor speed difference from a sensor to trigger this behavior.
Apr 5, 2021 at 5:19 AM
MARK0415
  • 7 POSTS
Sounds possible.
Rt rear adjuster was floating around in the drum.
Some teeth are damaged on trigger.
STEVE W.
  • 15,409 POSTS
That would do it. The sensor is reading the damaged teeth on the tone ring differently and kicking on the ABS. I have seen this when a tone ring was damaged, even worse when one cracks. Thing that stinks is having to pull those hubs...
MARK0415
  • 7 POSTS
How Can I disable abs?
And what happens when I do so?
STEVE W.
  • 15,409 POSTS
Well you can pull the fuse for the ABS, it will stop working but the light will stay on all the time. The base brakes will still work fine, you just lose the ABS...
MARK0415
  • 7 POSTS
Does that affect anything else?
MARK0415
  • 7 POSTS
I am old school. We did just fine without abs.
I really don't care for abs.
STEVE W.
  • 15,409 POSTS
If it has traction control it will stop working as well as the ABS.
MARK0415
  • 7 POSTS
Engine compartment fuse?
Or in car fuse?
MARK0415
  • 7 POSTS
Or can I unplug abs module pump or module valve?
STEVE W.
  • 15,409 POSTS
The fuses should be in the battery junction box and tagged as ABS
