Can you turn the pulley ok. If you can turn the pulley, then the compressor is bad. If the pulleyis hard to turn, but you can turn the compressor clutch, then the bearings are bad. Either way, the best way to remove it is from underneath, but remove the fan and shroud and take it up in front of the radiator.
SPONSORED LINKS
Thursday, April 10th, 2008 AT 4:33 PM
