steering hard to turn when I drive slow
1999 FORD TAURUS
108,000 MILES • 6 CYL • FWD • AUTOMATIC
ROCKY23
when i stop my car or when i drive slow like in parking lots..its really hard to turn the steering..but it works good at high speeds...i took it to a local mechanic and he inspected the car and guessed it might be a steering pump problem and said may cost 450 dollars... when he lifted the car in air he said the steering is working but when weight is applied the steering fails...so he came to conclusion that its not rack and pinion but the pump....i am ready to pay but wats bothering me is...after paying 450...if it doesnt work ....so can u let me know....he is right
Jan 3, 2008 at 3:40 PM
ZUE
  • 76 POSTS
The pump does seem like the possible solution. If you did not check to belt then do so. A loose belt can casue the same semptoms. I am sure the mechanic checked this as it is a basic test but do a visual inspection of belt and fluid level.
A new power steering pump is about 50.00 and a new belt is about 30.00. 450.00 sounds a bit high for parts and labor as this is about a 1 to 2 hour job. I estimate about 250.00 for the job at 80.00 per hour job rate. Get a second quote if you do not want to do it yourself.
Jan 3, 2008 at 3:58 PM
ZUE
  • 76 POSTS
Did you fins a solution to your earlier problem?
Dec 5, 2010 at 6:55 AM
