1999 Ford Taurus PO320
SHITHEAD
Computer problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
can't afford manual. If I could pay that I would have a mechanic trouble shoot my car, and fix it. I do not work on cars I am a poor boy trying to save money that I don't have. Help me figure out this code, please. I am already $150.00 in the hole for a scanner. I am going broke fast.
Jul 14, 2008 at 2:51 PM
BMRFIXIT
  • 19,053 POSTS
Its not cheep to own and operate a car nowadays
never mine trying to fix it
code 320 is related to ignition system
this is what the Mitchell recommend to do
KOEO & Continuous Memory DTC P0320:
Erratic Ignition
This DTC indicates that successive erratic Profile Ignition Pulses (PIP) signals have occurred. Possible causes are:
? Loose Wires &/Or Connectors
? Short Circuit To Ground In Ignition Secondary System (Coil, Wires Or Plugs)
? Incorrect 2-Way Radio Installation
Ensure 2-way radio antenna and all harness connections are properly installed and routed. If any faults were present, repair as necessary
good luck
Jul 14, 2008 at 3:01 PM
