1999 Ford Taurus trouble code PO320
1999 FORD TAURUS
SHITHEAD
Computer problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic ? miles
What do I have to do to find out what is causing this code?
Jul 14, 2008 at 2:40 PM
BMRFIXIT
  • 19,053 POSTS
1) KOEO & Continuous Memory DTC P0320: Erratic Ignition
This DTC indicates that (2) successive erratic Profile Ignition Pulses (PIP) signals have occurred. Possible causes are:
 Loose Wires &/Or Connectors
 Short Circuit To Ground In Ignition Secondary System (Coil, Wires Or Plugs)
 Incorrect 2-Way Radio Installation
Ensure 2-way radio antenna and all harness connections are properly installed and routed. If any faults were present, repair as necessary
Jul 14, 2008 at 2:48 PM
