1999 Ford Taurus OIL PUMP
1999 FORD TAURUS
155,000 MILES • 6 CYL • FWD • AUTOMATIC
A_MARIN80
IS IT HARD TO REPLACE THE OIL PUMP? THE OIL LIGHT IN THE DASH COMES ON AND BLINKS AS SOON AS I TURN ON THE CAR.
Dec 17, 2008 at 10:15 AM
SCHRIMPIEMAN
  • 166 POSTS
You're in for a good time...
Check the link
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
or just go to the autozone home page and navigate to your vehicle from the repair guide.
Oil pump is behind front cover, behind harmonic balancer, and behind just about everything else.
Oh, and you need to remove the oil pan, too.
Before you tackle the oil pump, hook up a pressure gauge to read actual pressure. You may just have a defective oil pressure sending unit.
If you have low pressure, try using the next weight motor oil. Eg: If you usually use 10W30, try going with 2qts of 10W40 and 3qts 20W50 mix. The weight mix is not critical. Just don't mix oil manufacturers / brands.
Dec 21, 2008 at 12:39 PM
