1999 Ford Taurus Interior light
1999 FORD TAURUS
193,000 MILES • 6 CYL • 2WD • AUTOMATIC
GKINGBEV
My interior light is staying on when all of the doors are shut. Where are the switches in the door located?
Aug 5, 2008 at 10:41 AM
JUSTDON
  • 161 POSTS
First thing to check would be to make sure the dome light hasn't been turned on.
If not, Try spraying WD40 in the door latches and opening and closing the door (several times) while adding WD40. This may take 20-30 times for each door. Just keep going from door to door and the light should go off at some point.
Aug 6, 2008 at 1:22 AM
