1999 Ford Taurus Car overheating daily
REDBIRDZ97
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 115,000 MILES
Hello, I have a 1999 ford taurus 3.0 liter engine. I have replaced thermostat, water pump and the cooling resevoir twice on this car. Seems to do fine on the highway but as soon as you get off or run it in the driveway it consistantly overheats and blows through the side of the cooling resevoir. Not out the cap where it is supposed too. I have flushed the radiator, the cooling fans are running. I have looked in the oil and haven't seen any of the telltale milky white leading me to believe that the headgasket is fine and outside of the water getting pushed out of the resevoir I have noticed no coolant leaking/disappearing. Any clue what is going on here?
Monday, June 22nd, 2009 AT 8:01 PM
  • 109,885 POSTS
Have you flushed the radiator and engine block? Also, have you checked engine compression to make sure it's not a head gasket? Also, when this happens, have you checked to see if one of the radiator hoses is collapsing?
Tuesday, May 2nd, 2017 AT 4:14 PM
REDBIRDZ97
Yes I have flushed both radiator and block. No I haven't checked the compression but with this problem happening for a few months now if it was the head gasket I would have thought that I would have seem something in the oil. Maybe not? Haven't noticed hoses collapsing will check that tomorrow. Is a rotted out radiator a common possible thing? Meaning the inner workings are somewhat rusted away? When I flushed it I did and still do get somewhat of a rusty color even though I use a green antifreeze not the orange stuff. And this is when I flush from the resoviour through the radiator taking the hose loose at the thermo stat before it goes back into engine.
  • 109,885 POSTS
Actually, you don't have to see coolant in the oil to have a bad head gasket. It could be leaking compression and you would never know.
As far as the radiator, what happens is they corrode inside and don't allow the coolant to properly circulate. If there are any radiator shops near you, you may want to remove the radiator and have it rodded out. They actually boil the radiator in a solution that will eliminate the corrosion and build up. Where I am, near Pittsburgh, there is a shop that does it for around 30 bucks, and when they finish, you can't tell the radiator from a new one. They have always worked for me for years after the work is done.
Keep in mind, flushing from the overflow really doesn't allow that much pressure to clean out the radiator, so this may be a condsideration for you.
REDBIRDZ97
Thank you very much, gave me some other things to look at. Appreciate all the help, I'll see where it goes from here.
  • 109,885 POSTS
Let me know what you find.
