1999 Ford Taurus Engine Overheating
LUIS3AMAYA
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 125,000 MILES
Any advice or suggestions? My car is overheating(the temp gage rises to hot). I have replaced the thermostat and the radiator cap and their are no
leaks that I can see( no fluid on the ground).
Sunday, August 22nd, 2010 AT 4:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure radiator fan(s) are coming on properly. Purge system to ensure no air is in cooling system.
Sunday, August 22nd, 2010 AT 5:47 PM
Check the radiator if its clogged and the water pump -pumping coolant thru out the engine, also if the cooling fan is coming on. Did you bleed the cooling system when you replaced the Stat if not try bleeding it and see what happens.
Sunday, August 22nd, 2010 AT 5:51 PM
