1998 Ford Taurus Door ajar and interior lights
1998 FORD TAURUS
JOZEFSMITH
Interior problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
My friend got out of the car and the door ajar light and interior lights stayed on. There is an alarm, but i think its disconnected. I have to disconnect the battery to keep the lights off. When i reconnect it, the lights go on. Is there something i can do to stop this?
Jan 25, 2010 at 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect faulty or sticking door ajar switch. try lubricating each door latch with some WD 40 and work the WD 40 in really good by working it in with the latch. if it doesnt help you will have to test each ajar switch to see which is faulty and needs replaced
Jan 25, 2010 at 1:04 PM
JOZEFSMITH
Thanks so much guys....however, when I was checking each door, then connected the battery to see if it when on..it didnt! It was prob just stuck or cold. I'll def keep you in mind and tell my friends about you and your quick, smart responses!
Jan 27, 2010 at 12:32 AM
