1996 Ford Taurus interior lights
TALLTODDY
  • 1996 FORD TAURUS
  • 6 CYL
  • 120,000 MILES
When the car is shut down, the interior door lights and the ones under the dash stay on. Not the dome light, just those. This has never happened before. I had to remove the fuse to stop the battery from draining. Any thoughts on whats happened? There is no door ajar light on, but it behaves as tho one is.
Saturday, September 4th, 2010 AT 11:05 AM
BILLYMAC
  • 2,204 POSTS
Try disconnecting neg batt cable for 30 mins see if it resets the bcm
Saturday, September 11th, 2010 AT 12:28 PM
TALLTODDY
  • 5 POSTS
The car also makes a humming noise when idleing by the belts. This cant be good right? :'(
Sunday, September 12th, 2010 AT 11:15 AM
BILLYMAC
  • 2,204 POSTS
Well maybe not that bad a humming would indicate a relay stuck find the relay that is humming and replace it may fix the whole prob
Monday, September 13th, 2010 AT 4:41 PM
