Follow the + battery cable to the starter solenoid, when the car is acting up, use a screwdriver and connect the terminal the + battery cable connects to, and the small single blur/red wire without unplugging the wire if it cranks now, replace the solenoid. Remove the Negative _ battery cable before doing the replacement, and attach it last! This will protect against accidental shorting of wires.
SPONSORED LINKS
Friday, February 17th, 2017 AT 2:58 PM
