1998 Ford Taurus Awful grinding/whining noise in engine when
GLDDSTGPSY
Steering problem
1998 Ford Taurus V6 Front Wheel Drive Automatic 128900 miles
My car recently developed a whine in the engine, which was accompanied by a horribly loud grinding-like sound when turning the steering wheel. The whining sound is constant, and increases when I push on the gas pedal. I was convinced it was the power steering pump, and had it replaced. The mechanic told me it would make the same sound for a few days until the water evaporated out of the pump. Well, three days later, the grinding sound is worse, and it is getting a little harder to turn my steering wheel. I also feel a slight grinding sensation both on the steering wheel and the gas pedal when I turn the wheel. Any ideas what the problem may be?
Dec 7, 2007 at 7:05 AM
MERLIN2021
  • 17,250 POSTS
Sounds like the steering mechanism...the rack is in need of replacement to me...
Dec 7, 2007 at 7:18 AM
  • 55,694 POSTS
I would replace the high side hose but first drive the car for a short time, (2 minuets) when the car is off, remove the power steering pump lid and if there are air bubble still in the fluid I would remove the pump because the one you have is defective.
Jul 13, 2024 at 11:57 AM
