1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
My 98 Taurus started missing and the ck. Engine light came on, so I eased it home but could barely drive it into the garage. I checked it with a scanner, the code 0304, #4 misfire came up. I replaced the plugs no change, I ohms checked the wires, all had 8,000 ohms of resistance. What's next? The coil pack is around $100, is there anyway to test the coil first? The car is just a piece I drive back and forth to work, I don't want to spend much on it. Can you help?
SPONSORED LINKS
Friday, January 23rd, 2009 AT 7:25 PM
