One of the most common causes for excessive white smoke coming out of the tail pipe is a blown head gasket. When the head gasket fails it will allow coolant to mix with oil. This will lead to white smoke.
The white smoke can also be due to cracked cylinder head, engine block failure, leaking intake manifold gasket.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Usually when oil and coolant mix the oil color changes to a milky white color. So first check the oil. You also need to check the coolant level.
Here is a helpful guide on how to test for blown head gasket:
Please let me know your findings.
SPONSORED LINKS
Sunday, January 16th, 2022 AT 1:19 PM
