1997 Ford Taurus Wiper speed
1997 FORD TAURUS
DEHERMAN
Electrical problem
1997 Ford Taurus 6 cyl Two Wheel Drive Automatic
While they still work at normal speed, but I can no longer select hi speed or delay on the wiper blades. (unless I turn on one of the blinkers) I am guessing it is a relay, but I don't know which one or where it is. (I already had the accessory delay relay checked)
Thank you for your help.
Mar 19, 2009 at 5:49 AM
JGAROFALO
  • 489 POSTS
The wipers and blinkers are unrelated except through the switch. This points to a problem with the switch. Also check grounds.
There is no relay as such for the wiper speeds. The delay is controlled by a module under the dash, and the high speed is direct wired to the hgh speed terminal of the wiper motor.
Mar 19, 2009 at 12:54 PM
