1997 Ford Taurus Interior Light and Door Locks
1997 FORD TAURUS
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAULIE
The problem we're having is with the Interior light and the door locks. (Could it be the Relay?)
When the car starts the interior light turns on as does the panel light for the doors showing the doors open. Initially we are unable to turn the interior light off or lock the doors. Once we start driving the locks lock themselves and the Panel light turns off. The interior light is another story and is vary erratic. The light sometime stays on for a long time and once we park the car and leave it eventually turns off.
Any suggestions would be greatly helpful.
Thank You,
Mar 16, 2008 at 12:11 PM
SERVICE WRITER
  • 9,123 POSTS
First thing I would do is to lubricate the door latches heavily with a thin lube such as wd-40 and open and close the doors 15-20 times and lube again. Most likely this will remedy the problem.
Mar 16, 2008 at 12:17 PM
