I have a 97 ford taurus that intermittantly/randomly shuts down in warmer weather. I am fairly sure the fuel system is shutting down as you can't hear the priming humm when you turn the key forward slightly. After 20-30 minutes you can start the car back up and it runs fine. I have taken it to the mechanics several times but since there is no error code they can't help. They think it may be the fuel pump but until it perminatly fails they are not sure. There is no overheating indication. It has been doing this for over a year. I have already changed the cables, spark plugs, fuel filter.
Thanks For your time
SPONSORED LINKS
Wednesday, May 26th, 2010 AT 12:37 PM
