1997 Ford Taurus
RKNOWLES
  • 1997 FORD TAURUS
1997 Ford Taurus
How do I change the rear turn signal brake lamp?
Friday, April 24th, 2009 AT 2:00 PM
  • 109,951 POSTS
You need to remove the light assembly. From inside the trunk, you may need to remove the carpet near the tail light to be repaired, but you will find I thing 4 wing nuts that you unscrew. Once they are off, the assembly will pull out and you will have access to the bulbs.
Wednesday, May 6th, 2009 AT 10:03 PM
