1996 Ford Taurus need to reset comp
1996 FORD TAURUS
130,000 MILES • 6 CYL • FWD • AUTOMATIC
KWYK1
  • 7 POSTS
engine light cam on; it was the cam sensors i replaced both. the trouble light still comes on,for same prob.
I have disconected the battery for more than a day or to.
Its memory is still intact even the radio presets.
How can i reset this.
Mar 6, 2009 at 11:06 AM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
once you have disconnected the battery for at least 5 minutes .. and then reconnected ..does the CEL/MIL could back on immediately ? or after driving the vehicle for a while ? Vehicles equipped with engine or transmission computers may require a relearn procedure after the vehicle battery is disconnected. Vehicle computers memorize and store vehicle operation patterns for optimum driveability and performance. When the vehicle battery is disconnected, this memory is lost. Default data is used until new data from each key start is stored. As the computer restores its memory from each new key start, driveability is restored. Driveability problems may occur during the relearn stage. Depending on the vehicle and how it is equipped, the following driveability problems may exist: Rough or unstable idle. Hesitation or stumble. Rich or lean running. Poor fuel mileage. Harsh or poor transmission shift quality. To accelerate relearn process after battery removal and installation, vehicle should be road tested in the following manner: Vehicle at normal operating temperature (cooling fan cycles). Accelerate at normal throttle position (20-50%). Cruise at light to medium throttle. Decelerate to a stop, downshifting and using brakes normally.
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_5.png
Mar 6, 2009 at 11:22 AM
KWYK1
  • 7 POSTS
have treid no battery for 6months still same result.
It still come up as same code each time.
Is there a way to reset it to relern without a mechanic
Mar 6, 2009 at 11:35 AM
KWYK1
  • 7 POSTS
i even removed the maint fuse and the battery,thinking that would work and it did not.
Mar 6, 2009 at 11:38 AM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
does the light come back as soon as you reconnect the battery or AFTER you have driven it ???
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_8.png
Mar 6, 2009 at 11:42 AM
KWYK1
  • 7 POSTS
yes. and it comes back as same code.
Mar 6, 2009 at 1:51 PM
KWYK1
  • 7 POSTS
it has even been code complete, 10 miles later same ck eng light ,same code ./
Mar 6, 2009 at 1:52 PM
KWYK1
  • 7 POSTS
grease monkey and checkers and auto zone tried to clear no result.
Mar 6, 2009 at 1:54 PM
KWYK1
  • 7 POSTS
no comp prob, no part prob.
car just wont let go of its memory
Mar 6, 2009 at 1:55 PM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
You will need to check the wiring for shorts etc. !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_19.png
Mar 6, 2009 at 2:04 PM
