HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Cylinder Head
Gasket
Replace/Remove
1996 Ford Taurus head gasket
NERD1366
MEMBER
1996 FORD TAURUS
6 CYL
2WD
AUTOMATIC
100,000 MILES
I am changing a head gasket in 1996 ford taurus, I need to know the torque sequence. Could u please help me. Thank you
rich
Sunday, April 20th, 2008 AT 7:59 PM
NERD1366
MEMBER
SPONSORED LINKS
Sunday, April 20th, 2008 AT 8:00 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Replace/Remove Content
1996 Ford Taurus Head Gasket
I Replaced My Head Gasket And The Engin Is Running Hot Also Replace Thermostat. Its Also Missing A Little I Change Spark Plugs
Asked by
whobbs
1996
FORD TAURUS
Head Gaskets Change
I Changed The Head Gaskets On My 3.0l Ford Taurus, Now It Will Not Run Or Start Up. It Is Getting Fuel And Spark. I Double Checked All...
Asked by
jwalker1979
2000
FORD TAURUS
2002 Ford Taurus Head Gasket Needs Replacing?
(car Had One Previous Owner) I Discovered That The Fluid In The Radiator Was Like Muddy River Water And The Reservoir Had Obviously...
Asked by
smudges
2002
FORD TAURUS
94 Ford Taurus Gl
A Friend Of Mine Has A Ford Taurus V6 3.8l. The Head Gasket Is Gone And The Garage I Work At On Saturdays Said That They Could Replace The...
Asked by
canavery
1994
FORD TAURUS
What Is Causing This?
I Have A 1999 Ford Taurus I Changed The Head Gasket, And After I Put Everytning Back Together And Started It Up, It Makes A Popping Sound...
Asked by
Aaronmaster
1999
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Coolant Mixing With Engine Oil
Engine Oil Change and Filter Mercedes
Oil Change & Filter Replacement Ford Escape
Online car repair manuals
