1996 Ford Taurus CV inspection
DAM5741
  • 1996 FORD TAURUS
  • 6 CYL
  • FWD
  • 160,000 MILES
I am hearing a grinding noise when I go around a curve, not really when I make a turn. I am wondering if it is the CV joint? How do I check to see if this is the problem? Also is this an easy enough fix that a novice can take and do?
Thank you in advance for your help.
Tuesday, December 29th, 2009 AT 4:55 PM
BMRFIXIT
  • 19,053 POSTS
Check if boot is ripped and if the grease out
Need tools and some know how to do
Sunday, September 30th, 2018 AT 12:53 PM
DAM5741
I have looked at the CV joint boot and there are no rips or tears in it. I also don't see any grease around any other parts. Could it be wheel bearings? Or any thing else?
BMRFIXIT
  • 19,053 POSTS
If clucking as you turn suspect CV axle
if humming (air plane )as you driving and get louder as you go faster if you try and turn a bit noise fade away or change
