1996 Ford Taurus Auto Transmission slippage in drive
RODRACQUET
  • 1996 FORD TAURUS
Transmission problem
1996 Ford Taurus 6 cyl Front Wheel Drive 80000 miles
Greetings from Australia. I guess trying to fix a Taurus transmission is a game of eliminate the myriad of possibilities. The symptom is that 1st and 2nd run fine but in drive and neutral the revs are limited to 4000rpm and it sounds like the engine in splurting. I will be going to an auto tech tomorrow to find out what the codes are. I have had this problem before and sometimes it resolves by resetting the computer. This time it did not fix. I find that when the engine runs rough or you go over a dip in the road that this problem activates.
My gut feel says that a sensor is likely to be a culprit. Maybe the engine can send a signal to the transmission saying it is in trouble and this is the transmission response.
One guy suggested that the MLPS is often the culprit. The code book suggests doing a transmission service which it may not have had done for a long time, certainly not since I got it at 96000k 60000m
Monday, August 31st, 2009 AT 3:29 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You are doing the correct thing by getting the code read as there is no way to second guess these problems, I would be interested in the codes that are set, post them here and I will look them up and see what they are, start here.
Mark (mhpautos)
Latrobe Valley, Vic, Australia.
( I bet you never experted an Aussie to answer you on an American car site.)
Monday, August 31st, 2009 AT 5:05 AM
RODRACQUET
Codes read were P1705 not in park or neutral during park and P1464 AC demand on self test range. Codes could not be cleared either by home solution (disconnect the battery) or through scan request.
Fault seems to be the TRANS RANGE SENSOR which was replaced with a second hand unit. After installing this new unit codes would clear and car runs fine.
Hopefully, a few more years of happy motoring?
Wednesday, September 2nd, 2009 AT 8:07 PM
