2005 Ford Taurus Trans slipping in higher gears
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOB13873
  • 5 POSTS
The car drives fine in 1st gear. I can punch the gas and it takes off with no detectable slip. At about 25-30 mph when it should be shifting to a higher gear the engine revs and speed does not increase. I want to make sure there are not some sensors I should be suspecting before I jump to replacing the trans.
May 10, 2010 at 1:27 PM
BMRFIXIT
  • 19,053 POSTS
check for codes
codes should indicate to what is going on inside the tranny and if tranny at fault or bad sensor
or solenoids
May 10, 2010 at 1:31 PM
BOB13873
  • 5 POSTS
I have a scanner which shows no active codes. Even with the dash saying "Check transmission"
May 10, 2010 at 1:34 PM
BMRFIXIT
  • 19,053 POSTS
scanner or an OBDII reader ?
May 10, 2010 at 1:38 PM
BOB13873
  • 5 POSTS
correction, reader
I was kind of hoping for a "in my experience those sympoms generally turn out to be..." type answer or it sounds like....
May 10, 2010 at 1:46 PM
BMRFIXIT
  • 19,053 POSTS
with the reader you can not access all code modes
make sure fluid is in good condition and at the correct level
remove Tranny oil pan and inspect filter and gasket
Check for excessive clutch debris in the transmission oil pan
May 10, 2010 at 2:08 PM
BMRFIXIT
  • 19,053 POSTS
most likely it a mechanical failure as if its an electrical , sensor or solenoid you would get a check engine light on and some P07XX's codes
May 10, 2010 at 2:11 PM
BOB13873
  • 5 POSTS
fair enough thank-you
May 10, 2010 at 2:31 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
May 17, 2010 at 5:47 AM
BOB13873
  • 5 POSTS
more information.
I got trouble code P0732. I did some research and found out there is a TSB for this issue. TSB 041512 or NHTSA Item # 10011157 but I cannot find a way to read the text of the TSB, only the summary. Do you have access or know where I can get the full text.
May 20, 2010 at 2:39 PM
BMRFIXIT
  • 19,053 POSTS
I AM away from my work PC
will look it up for you and let you know my finding tomorrow
May 20, 2010 at 2:45 PM
BOB13873
  • 5 POSTS
That would be great. Thanks
May 21, 2010 at 3:16 AM
BMRFIXIT
  • 19,053 POSTS
Search performed for "p0732" Press Ctrl+F to find exact text 4F50N TRANSAXLE NO 1-2 UPSHIFT AND DTC P0732
TECHNICAL SERVICE BULLETIN
Reference Number(s): 04-17-10, Date of Issue: September 6, 2004
FORD:2004-2005 Taurus, Freestar
MERCURY:2004-2005 Sable, Monterey
Superceded Bulletin(s): 04-15-12, Date of Issue: August 9, 2004
Related Ref Number(s): 04-15-2, 04-17-10
ARTICLE BEGINNING
DESCRIPTION
ISSUE
NOTE:This article supersedes TSB 04-15-12 to update the vehicle model years.
Some 2004-2005 Taurus/Sable and Freestar/Monterey vehicles, may exhibit a diagnostic trouble code (DTC) P0732 and a no 1-2 upshift condition. This may be due to an intermediate clutch piston seal becoming torn or loose (de-bonded) from the piston.
ACTION
To service, perform normal diagnosis per Workshop Manual. If the cause is determined to be internal to the transaxle, inspect the intermediate clutch piston seal. The outer clutch seal is bonded to the piston. If the seal is torn or loose replace the piston. Inspect the intermediate clutch plates and replace if necessary.
PARTS INFORMATION
May 21, 2010 at 5:55 AM
