Engine Mechanical problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
my car was making a knocking noise then all at once it quit and a big ball of smok came out of the car and all the oil poured out I costed home thankfuly
Thursday, June 5th, 2008 AT 9:15 PM
BLACKOP555
MECHANIC
First of all, where is the oil comming from? Where did the knocking noise come from.
And how long were you driving it like that?
Friday, June 6th, 2008 AT 7:24 AM
SJWW1013
MEMBER
It is comeing from looks like the oil pan and I drove just about 200 ft not far
Friday, June 6th, 2008 AT 8:28 PM
BLACKOP555
MECHANIC
Does car start now? Crank?
Run just fine?
Saturday, June 7th, 2008 AT 12:47 PM
SJWW1013
MEMBER
No it wont turn over as soon as it done that it died I coasted home
Monday, June 9th, 2008 AT 6:12 AM
BLACKOP555
MECHANIC
As long as it cranks I would like you to perform a few cranking pressure tests and record what you find when you post back.
Trying to figure out what is wrong.
Monday, June 9th, 2008 AT 7:34 AM
SJWW1013
MEMBER
It wont turn over should I try boosting it
Tuesday, June 10th, 2008 AT 7:17 PM
BLACKOP555
MECHANIC
Turning over means the vehicle starts, does your vehicle crank a.K.A attempt to turn over or does it sit there and click, or nothing happens.
Tuesday, June 10th, 2008 AT 9:31 PM
SJWW1013
MEMBER
It just clicks nothing happens
Wednesday, June 11th, 2008 AT 5:29 AM
BLACKOP555
MECHANIC
I would check checking for dirty or corroded terminals and charge the battery for starters.
Then I would try 12v direct on the starter, I have a feeling its jammed in the wheel or someting bad has happened in the resepects of the starter and flywheel.
Wednesday, June 11th, 2008 AT 8:26 AM
SJWW1013
MEMBER
Ok I jack the car up and looked there is a hole in the oil pan and I got afew pices out and one pice looks like a pice of a big ring
Wednesday, June 11th, 2008 AT 5:52 PM
BLACKOP555
MECHANIC
Deffinetely would take off the oil pan and see what can be seen, sounds like a blown piston ring or maybe somethign worse.
