2001 Ford Taurus Knocking at startup
2001 FORD TAURUS
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
TEXASTAURUS
I have a 2001 taurus and when I start it up I hear a knocking nosise, and it last for just a 1/2 min then goes away. Then when I am driving and come to a stop light I hear that same nosise and it goes away very quickly. It doesn't use any oil or has any performance problems, I drive 60 miles round trip everyday and change the oil as called for. Whats up?
Dec 16, 2009 at 8:58 AM
MMPRINCE4000
  • 8,548 POSTS
Start by checking oil pressure with mechanical gauge.
On a cold engine you would want at least 40-60psi.
If OK, then change oil and run magnet through used oil looking for any metal particles.
If OK, then you could have a accessory drive problem, like a tensioner or pulley.
On cold engine, remove serpentine belt, start engine and run for 30 seconds, you will get alt. light come on, but you are looking to see if knocking goes away.
If it does, then you have isolated problem to assy. side.
If you still have the knock after above and there are no metal particles in oil, remove flexplate (flywheel) inspection plate and check that all bolts to flexplate are tight and none are missing.
Dec 16, 2009 at 9:26 AM
TEXASTAURUS
What if i find metal in oil? Sounds like the noise is coming from the top of the engine area.
Dec 16, 2009 at 11:17 AM
MMPRINCE4000
  • 8,548 POSTS
Metal would indicated a bearing wear problem and would require extensive repair.
Hopefully is is an oil pressure problem that has not affected the bearings yet.
Dec 17, 2009 at 8:15 AM
TEXASTAURUS
any idea to the cost of getting the oil pressure checked? oil level is good and clean.
Dec 17, 2009 at 11:02 AM
MMPRINCE4000
  • 8,548 POSTS
Should not take more than an hours labor. They remove the electrical oil pressure sender and replace with a fitting connected to hose with gauge.
Crank and start engine and look at actual oil pressure in engine.
If low, could be an oil pump, oil pump pick up, clogged oil galley.
Dec 18, 2009 at 9:36 AM
TEXASTAURUS
I really appreciate that. Thanks a bunch, I talked to a mechanic and he said with that many miles i need to go to a 10w 30 thicker oil
Dec 18, 2009 at 10:54 AM
