1995 Ford Taurus Stick shift would move
SUDI
Other Category problem
1995 Ford Taurus Engine Size unknown Two Wheel Drive 230,00 miles
Last night my car would not unlock the auto gear shifter when pressed the brake and the button on the side will not go all the way in to unlock. shifter is on the floor. I allowed the car to warm up but still nothing.
Jan 4, 2008 at 11:34 PM
TAURUSWHEEL
  • 718 POSTS
If the floor shifter does not move when the car is in run and the brake pedal is applied, check these items:
stoplight switch, shift-lock relay, shift-lock solenoid, circuit.. Make sure your brake lights are working first,, in most cases it's the brake light switch has failed, hopefully yours.
Jan 5, 2008 at 1:20 AM
