Speedometer isnt working doesnt go up or down just doesnt move any suggestions?
Wednesday, August 18th, 2010 AT 8:08 PM
BLUELIGHTNIN6
MECHANIC
If it's analog than the speedometer cable has most likely came loose, check the rear of the instrument cluster to ensure it's hooked up there. If it is than inspect it at the tranny side to make sure it's in there good as well.
SPONSORED LINKS
Wednesday, August 18th, 2010 AT 8:33 PM
DELEON2010
MEMBER
1 POST
Ok thanks alot going to look into that before work tomorrow
