I HAD THE ENGINE CHECK LIGHT COME ON AND IT IS READING PO503. I NEED TO KNOW WHERE THIS VSS SENSOR IS LOCATED ON A 1998 FORD TAURUS. I HAVE HEARD THERE CAN BE UP TO 6 SENSORS. DOES THE CODE PO503 SPECIFY THE SENSOR OR DO I HAVE TO TAKE IT TO A TRANSMISSION SHOP TO FIND OUT WHAT SENSOR IS BAD. THE CAR IS SLIPPING IN SECOND AND THE SPEEDOMETER IS NOT WORKING PROPERLY. THE ONLY CODE THAT CAME UP WAS PO503. tHANKS, PAT
Jul 24, 2008 at 12:35 PM
