Something is moving while driving. Or is not fully engaging. There is a plastic gear on the final drive housing that may not be staying where it should. This engages another gear that is ion the shaft inside the small housing that is bloted to the transmission housing. This small gear is driven by the gear on the final drive unit, and in turn drives another gear on the top of the shaft. This gear is located in place by a thrust bearing and a roll pin. The gear on the top of this shaft is the one that drives the speedometer gear and speed sensor. One of these gears is not staying in place, or is not fully engaging. This could be a missing part (roll pin or thrust washer) or incorrectly installed part.
SPONSORED LINKS
Wednesday, May 5th, 2021 AT 12:12 PM
