Car is chugging awful and it seems like the oil smells if gas.
Mar 2, 2008 at 1:30 PM
SERVICE WRITER
✓Experienced Mechanic
Probably have a misfire happening. You can remove one plug wire from each spark plug, one by one t determine what cylinder is missing. There will be no change on the bad cylinders. Sounds like a lack of spark issue based on the excessive fuel although too much fuel can also cause a misfire.
