1995 Ford Taurus car wont start
LACEYJUNE2011
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 228,800 MILES
My car hasnt been starting. It use to be that you had to pump the gas to get it to start. Which made my brother think it was a fuel pump. But now when you turn the ignition it sounds like its gonna start then it goes to a sounds like a blet pretty much saying you dont hear much so my boyfriend and mom think its the starter. I just wanna find out what it could possibly be.
Wednesday, March 3rd, 2010 AT 12:13 AM
Pick your symptom: Get back with some feedback.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Wednesday, March 3rd, 2010 AT 12:22 AM
LACEYJUNE2011
Yes the battery is good its only about a month old. The spark plugs should be good just this september I had a tune up on the car. The only problem is lately we havent even been able to get the car to start. Like I said sounds like its gonna but then it goes to nothing.
Wednesday, March 3rd, 2010 AT 12:32 AM
