1994 Ford Taurus Warning Lights Flicker
MAY7MIRACLE
1994 Ford Taurus 175,000 miles.
When I first start my car all of the dash warning lights come on for a split second which is normal. But as I accelerate and get about 1/2 a block away all the lights will flicker and the car will "jump" like it is going to stall, but doesnt actually stall. This is a recent development. Then, when I went to start my car today, nothing happened! the dash lights came on but no start. It did start on the 3rd try and ran fine. I did notice that my radio was on am and the memory buttoms needed to be reprogrammed. The check engine light alone has never lit up, but the ABS light does come on momentarily while driving and then goes out. Any ideas? Young lady w/ little money and no car smarts! Thanks
Apr 14, 2006 at 6:21 AM
LOSONE
  • 1,616 POSTS
You are loosing ground in the electrical system. Check the ground from the battery to the engine, from the engine to the body and from the battery to the frame. REMOVE them and clean them well. Also check the + lead and insure the small wires leading from that post are connected. That should fix your problem. Good luck
Apr 14, 2006 at 10:34 AM
MAY7MIRACLE
You were right! I took it to a local auto shop and got it diagnosed and repaired for a total of $32.00.
Thanks so much!
Apr 17, 2006 at 3:55 AM
Suggested Repair
Clean the ground connections from the battery to the engine, the engine to the body, and the battery to the frame. Also inspect the positive battery cable and confirm that the small wires at that post are securely connected.
Conversation Summary
A 1994 Ford Taurus with 175,000 miles briefly flickered all dash warning lights and jumped as if about to stall after accelerating. It later failed to crank on the first attempts, lost radio memory, and showed a momentary ABS light, while the check engine light never stayed on. The expert attributed the symptoms to a poor electrical ground and recommended cleaning the battery, engine, body, and frame grounds and checking the positive cable connections. The owner confirmed that a shop diagnosed and repaired the problem for $32.
